I’ve got this 3 way plastic connector that connects 3 coolant hoses. I’d like to terminate one of the connections so it only connects two hoses.
I’ve got this connector I wanted to use to replace it, but sadly it’s too small
Get the right size/orientation connector.
Or put a short length of hose on the the unwanted outlet and block that with a suitable sized bolt, of course you will also need two hose clamps to prevent it coming apart or leaking.
But where do they sell these kind of connectors of various sizes? The one I have is a spare I had from some other hose.
I have a hose that goes on that connector and a clip, so I was thinking about a bolt, but wasn’t sure if it would start leaking at some point.
Hmm, I was only getting copper pipes and garden hoses when I was googling. But these examples have helped me narrow my search My hose inner diameter is 6mm, should I go for 6mm or 8mm connector(there is no 7mm)?
What are you thinking?
You’ll never get a 6mm hose onto an 8 mm connector, 6 mm hoses fit onto 6 mm connectors - simples but you will need a pair of hose clamps to suit the outer diameter of the hose.
Having looked at that photo again I’m wondering if a straight connector is what you want, looks to me as if a 90° elbow will be needed. The connector you list doesn’t specify a temperatures range?? The listings below does (-30° and +140°C) and if you do need a straight connector thay have that too.
I just thought the rubber might stretch enough to fit Though, I was thinking more about 7mm. Would rather ask than waste money on connectors I might never use
The picture is a bit misleading. I took out one hose (for inspection) from the 3way-connector point I had the easiest access to, but’s not actually the end I want to terminate. So, an elbow would work for the picture like you say, but not for the actual connection I want to make.
I did not consider the temperatures at all, though, thank you. I will go with the straight 6mm one from your link
Don’t forget hose clamps, coolant at engine operating temperature is under pressure which means there is a risk of the hoses blowing off the connector. There’s a table at the bottom of this listing for self clamping hoses to help you choose the correct size clamp according to the outside diameter of the hose.
Couldn’t I just reuse the original clips on the hoses that are in situ?
They’re a bit hard to make out in the original photo, but they’re like this:
Yes you can, didn’t realise you had them.
