It’s really stiff, no matter how much i keep lubing with wd40 / oil products.
But the main thing is the biting point is quite harsh, so clutch doesn’t engage for a bit, then suddenly almost fully engaged. So it there are a way of making it any smoother? Is it a new cable entirely?
I could only find bits about adjusting the freeplay via the adjusters at the lever and top of clutchbox, but this doesn’t really address my problem
i would take the cable off at the bottom and see how freely the cable moves then adjust from the bottom and fine tune with the top. might be a problem with the clutch if its not the cable
cool will give that a go. I suppose im looking for the cable to be moving freely at the bottom. I thought the adjusters just adjusted the freeplay, but maybe somethings going with mine and not adjusting the ‘width’ of the biting point
Check to make sure your bike doesn’t have a nylon sleeved self lubricating clutch cable. If it has and you have oiled it the nylon has swollen and the cable is landfill:)
You can adjust the biting point by the grub screw and locknut on the end of the clutch push rod:)
