Choosing Braided brake lines: some info.
To anyone considering fitting Goodridge or other Manufacturer’s braided brake lines, make sure you are 100% aware of what materials the fittings are made of. Some braided line manufacturers give you the option of having stainless steel, chrome plated mild steel, zinc plated mild steel, aluminium, or alloy fittings. This confusion can go unnoticed sometimes, especially when you’re buying from somewhere like ebay, where some Goodridge lines are described as their value range due to the material of the fittings.This is why I opted for H-E-L braided lines when getting mine. HEL only ever use Stainless Steel or Titanium fittings, on stainless steel hose with either Stainless steel or Titanium bolts.
They also come with a LIFETIME guarantee, and I’ve never heard anything but good about them.
See here http://www.h-e-l.co.uk/HEL_Performance_Motorcycle_Brake_Lines_Aluminium.htm to find out the dangers of fitting inferior aluminium fittings.
And no, I’m not on commission for 'em, I just like they’re way of thinking
Ton-Up.
I can completely concur, I don’t fit anything else.
Good bit of advice as I nearly brought some value Goodridge items last week, but never got round to it. I thought they would be fine. I’m just glad I never brought them now after reading that link. So is it OK to use the chrome plated mild steel
or only stainless steel?
And is there any difference between HEL and Goodridge?
yeah me too i’ve gone to Hel and back
Yes me too I am a devoted HEL brake hoses user.
“So is it OK to use the chrome plated mild steel
or only stainless steel?”
Chromed mild steel should be fine. I think its just the aluminium/alloy one’s that cause trouble. Call HEL to double check.
“And is there any difference between HEL and Goodridge?”
Well, Goodridge are a good brand, they’ve been going for years, and their better stuff is good, but just remember, HEL dont do a budget/value range of brake lines…Goodridge do.
Must get round to fitting mine… soon!
Cheers for the info Tonupkid!
No probs mr g
