My DRZ400SM has Off-Road wheels (I think from a DRZ400S), with a 44 tooth rear sprocket. I used the original chain from the SM wheels (which have a 41 tooth rear sprocket), and it was OK - the rear wheel was on the front of the adjustment rather than the back, but it wasn’t too tight, looked OK and worked well. Now some six months (and less than 1000 miles) later, it appears that the chain has stretched quite a bit, and is too loose. I could probably adjust the wheel back to tighten the chain, but I think it’s probably time for replacement.
I used the original chain with the idea that I would be able to swap between wheels without swapping the chain every time. However, that hasn’t happened, the bike has stayed on knobblies ever since I swapped them over! I’ll probably sell the SM wheels (any takers?), and just keep the off-road wheels on permanently. So, my questions:
- What length of chain should I go for? The “standard” length for the S model? What length is that exactly?
- Should I swap sprockets too? I got a new rear sprocket when I swapped the wheels over – no point changing a six month old one right? It’s not showing signs of wear (to my decidedly untrained eye). Not sure on the front, will take a look when I undress the bike, but if it looks OK…
- Any recommendations on an inexpensive but solid chain-breaker?
- Is this (http://www.amazon.co.uk/D-I-D-1265112D-Standard-Chain-Connecting/dp/B006WW2N78) the right kind of chain? Or do I need an O-Ring chain? Or an X-Ring chain? Or something completely different?
Cheers,
-simon
