btw, i just got a 48 ( 3 up) tooth rear sprocket to fit my fz1, but the chain is too short, shockingly… it’s an endless type of chain, so is it poss to add 2-3 extra links to accomodate the new sprocket?
or do i need to stretch it more, wait another 5k miles, or fit smaller front sprocket?
Why did you do that?Going down 1 tooth on the front is roughly the same as up 3 on the back and a lot easier to manage. It’s not wise to add 2-3 links, usually people get a longer chain.See if you can change the sprocket for a smaller front one and save the grief;)
i didn’t want a smaller front because of bigger strain on the chain as it wraps around a smaller circle, and longer wheelbase as the wheel goes back, and more wear to chain guide, aparently…
i guess i have no choice really, well, until the time comes to replace the chain anyway.
To be honest mate, going down 1 tooth on a front makes such a minimal difference to chain wear and stress. Wrap a chain in half and see how tight it will go, almost back on itself.
you might be right, it’s only 1 down from 17, and some bikes have 15 as standard. i’ve just bought one off fleebay, now thinking about fitting -1 +3 at the same time, make it a wheelie machine
