Noticed the break light isn’t working off the front break on the bandit.
Just replace the break light switch and it’s made no difference any suggestions on what to look at next or does anyone know a good sparks in or around Victoria?
Follow the wiring with a continuity tester, till you find the break in the circuit.
I would have thought it was the switch, but if you’ve just changed it, and you’re sure it’s not that, then the only other thing you can do is follow the circuit.
Don’t know any good sparks…(not saying there aren’t any, just don’t know any sparks at all).
is it deffo working from rear brake?
Yep back break is fine
a wire from the front switch must of worked loose
Just had another look and I’m now thinking it’s the connector block, I reckon I’m not getting a good connection
if u have a bike manuel it should give you a list of things to check i think u may be right tho
