Wondering if anyone has any experience of the following:
Bit of background first - my kwak has sat for a few months doing nothing while I used my other bike (I should have drained the carbs etc but was a lazy bastard).
Took it out the other day and it was running fine - few miles later engine started stuttering then cut out completely had to wheel it home.
Started it up again today - same thing - everything fine, started stuttering a mile down the road- cut out.
I’m assuming this is a result of storage - gummed up carbs/crap in the tank etc?
I’ve had that exact problem twice from a torn/misplaced carb diaphragm, but it could be a needle sticking etc or even spark related. Check the carbs first! (or just drain them and run some redex through if you’re feeling lucky!)
Just had a word with a really experienced bike mechanic I know - he reckons that if the bike runs for a while ok it’s unlikely to be carbs but is more likely related to fuel supply - either a gummed fuel tap/fuel pump.
I guess i’ll check these out before I get to the carbs.
FFS after reading 250 different threads on ‘help my zx7r won’t start/cuts out’ I’ve come to the conclusion the Kawasaki ZX7R is like the millennium falcon out of Star Wars, it’s an unreliable piece of **** but when it’s actually working it’s awesome.
Now I’m trying to work out if it’s the infamous ‘gray wire problem’:
