Where do you store it when you’re not using it? This applies more when its raining as you can’t exactly put it in the house to get the carpets wet so what do you do?
Also, one other thing is it bad to put the cover on straight after using the bike i.e. hot exhaust etc…??
Roll it up in a ball and put it somewhere safe - that’s about as much use as I can be on that first question But I always wait about 30 mins before putting the cover on, as the exhaust can melt it quite easily. (Hasn’t done yet, but it did melt the plastic covering on my chain when I put that on too quickly.)
I put mine on straight on. I did melt a small hole once when the end of the exhausts touched the thin part of the cover… Just careful from now on that they don’t touch (they’re underseat so only the ends can touch)
When I don’t use it I leave it locked where the bike is normally locked. It stays off the floor with the waterproof side up.
If I have to bring it in the house, just leave it in a bin liner…
