Hel and Venhill are different types of lines not just different brands.
Hel are swagged, the ends are fixed in place and if the lines get damaged the whole thing needs replacing. This type tend to be safer as cack handed mechanics can’t screw up building them and its easier as well as safer to fit coloured covers on them.
Venhill are built up lines using pressure olives to seal. Harder to build and harder to fit full length covers on but individual parts can be replaced if need. Tend to be more expensive than swagged fittings.
Hel are also a UK company so bit pointless importing from the US, it’ll cost more.
I think I’ll go with the HEL and have a crack at fitting them myself!!!
I’ve never done this before so if anyone has any gems of advice to bestow upon me, or can point me in the direction of a good write up for a GSXR 600 K7 now’s the time LOL
I fitted a set this weekend and the fitting is easy enough, bleeding them is a bit awkward until you have worked it out.My advice would be to cover everything because the fluid gets everywhere (needs washing of paint pretty quickly if it does spill), get yourself one of those £5 one way bleed valves from Halfords - it makes the job easier if you are doing otherwise you run out of hands. Good luck:)
