2022 Triumph Speed Triple 1200 RR
SPECIFICATIONS
ENGINE & TRANSMISSION
Type
Liquid-cooled, 12 valve, DOHC, inline 3-cylinder
Capacity
1160 cc
Bore
90.0 mm
Stroke
60.8 mm
Compression
13.2:1
Maximum Power
180 PS / 177.6 bhp (132.4 kW) @ 10,750 rpm
Maximum Torque
125 Nm @ 9,000 rpm
Fuel System
Multipoint sequential electronic fuel injection with electronic throttle control
Exhaust
Stainless steel 3 into 1 header system with underslung primary silencer and side mounted secondary silencer
Final Drive
X-ring chain
Clutch
Wet, multi-plate, slip & assist
Gearbox
6 speed
CHASSIS
Frame
Aluminium twin spar frame, bolt-on aluminium rear subframe
Swingarm
Aluminium, single-sided
Front Wheel
Cast aluminium, 17 x 3.5 in
Rear Wheel
Cast aluminium, 17 x 6.0 in
Front Tyre
120/70 ZR 17 (58W)
Rear Tyre
190/55 ZR 17 (75W)
Front Suspension
Öhlins 43mm fully adjustable USD forks, 120mm travel. Öhlins S-EC 2.0 OBTi system electronic compression / rebound damping
Rear Suspension
Öhlins monoshock RSU with linkage, 120mm rear wheel travel. Öhlins S-EC 2.0 OBTi system electronic compression / rebound damping
Front Brakes
Twin 320mm floating discs. Brembo Stylema monobloc calipers, OC-ABS, radial master cylinder with separate reservoir, span & ratio adjustable
Rear Brakes
Single 220mm disc. Brembo twin piston caliper, OC-ABS. Rear master cylinder with separate reservoir
Instruments
Full-colour 5" TFT instruments
DIMENSIONS & WEIGHTS
Length
2085 mm
Width (Handlebars)
758 mm
Height Without Mirrors
1120 mm
Seat Height
830 mm
Wheelbase
1439 mm
Rake
23.9º
Trail
104.7 mm
Wet weight
199 kg
Fuel Tank Capacity
15.5 litres
FUEL CONSUMPTION
Fuel Consumption
6.3 litres / 100 km
CO2 Figures
144 g/km
Standard
EURO 5
CO2 emissions and fuel consumption data are measured according to regulation 168/2013/EC. Figures for fuel consumption are derived from specific test conditions and are for comparative purposes only. They may not reflect real driving results.
SERVICE
Service interval
10,000 miles (16,000km)/12 months
