That’s not how keyless works in cars. I remember reading the write up of the first test of the then new keyless Megane. The journalists swapped cars when they finished the test and drove home. It was only parking up on his London street that the Megane driver remembered the other journalist still had the key. He knew if he switched off the engine he couldn’t switch it back on, he was also afraid there was no way to lock the car (on the Scenic there is a physical switch on the outside which will lock it).
I thought the Fireblade ignition switch was pretty easy to find when I sat on it today. If you are heading up to the show tomorrow get there before it opens as there were huge crowds from around 11.
