Dear All & Greetings.
My 2001 KAWASAKI ZX600-E7 has an ignition fault. Won’t start. Turns over, lights work and fuel is getting to the spark plugs. No spark.
Does anybody know of a common fault with the ignition system on these bikes? Alternatively, I would be grateful for advice on which forum to post in?
Thank you.
Ridewell500
If you are 100% sure there is fuel getting through and there is no spark at all on any of the plugs I’d check the ignitor box for loose connections.
If it was plugs, leads or coils you would have spark at one or some plugs.
Thanks very much for your help. Good suggestions and I’ll keep in touch. Thanks again.
did it suddenly stop working one morning, and if you have definietely checked there is a spark or not and their is fuel…then yes likely the faulty lies simply within your ignition circuitry…let us know what it is if you find out
