The new Super Tenere is the new R1 of the adventure world. Why? because alot of the tech from the sports bike has been transfered to it.
Most importantly the crossplane crankshaft. The R1s crossplane crank minimises inertial torque and allows to make the most of the available torgue.
So putting that engine in the Super Tenere, should allow the full use of the 110bhp and 84lb/ft whether on dirt, sand or road.
The new adv bike also has three modes of traction control. Unline the ABS this can be turned off.
This seems abit odd as Yamaha seem serious about it off road capabilities, giving it spoked 19-inch front wheel and a 17-inch rear.
It does look good tho
Specs:
ENGINE
Type: Liquid-cooled, 4-stroke, DOHC, inline 2-cylinder, 4-valve, fuel injected, twin spark engine
Displacement: 1199cc
Bore x stroke: 98 x 79.5 mm
Compression ratio: 11.0:1
Firing intervals: 270- and 450-degree points
Max. Power: 80.9kW (110PS) @7,250rpm
Max. Torque: 114.1 Nm (11.6kgf・m) @6,000 rpm
Lubrication system: Dry sump
Fuel supply system: Fuel Injection
Clutch type: Wet, multiple-disc diaphragm spring
Ignition system: Twin spark
Starter system: Electric
Transmission system: Constant mesh, 6-speed
Final transmission: Shaft
Throttle system: Yamaha Chip-Controlled Throttle (YCC-T)
Yamaha D-MODE: 2 modes, Sport (S) and Touring (T)
Traction control: 3 modes, TCS1, TCS2 and OFF
Exhaust System: 2-into-1
CHASSIS
Frame: Steel tube backbone
Front suspension: Upside-down telescopic fork, 43 mm inner tube, adjustable preload, compression and rebound damping
Front wheel travel: 190 mm
Rear suspension: Monoshock, adjustable preload and rebound damping
Rear wheel travel: 190 mm
Front brake: Hydraulic Twin 310 mm wave discs, ABS/Unified Brake System
Rear brake: Hydraulic Single 282 mm wave disc
Front tyre: 110/80/19
Rear tyre: 150/70/17
DIMENSIONS
Overall length: 2,250 mm
Overall width: 980 mm
Overall height: 1,410 mm
Seat height: Adjustable 845-870 mm
Wheelbase: 1,540 mm
Min. ground clearance: 205 mm
Wet weight: 261 kg (includes full oil and fuel tank):
Fuel capacity: 23 litres
Oil capacity: 4.2 litres
https://www.youtube.com/v/CxK677pPCcA&hl=en_GB&fs=1&
