X-Ring or O-Ring
Need to order a new chain and sprocket…
The great question is what do I go for on the blade?
Currently have standard front sprocket and 47 on the back… (that’s how it was when I purchased the bike last year)
But do I go X-Ring or O-Ring for the chain…and what manufacturer for chain/sprocket?
I see/hear DID is good…what are my other options?
Thanks in advance
As with most things…
It all depends on how much you want to spend.
DID X-ring with anodised sprockets (“Gold”) are the bees
and that could be why they cost more :smiley:
If you want cheaper then… O ring and steel sprockets
If you want really expensive buy the Honda parts but
they are probably DID anyway :w00t:
O ring will be fine, Xring will be better. as far as I know of them anyway.
I use AFAM XS-ring Chains & I also have a Scottoiler & every week clean & oil up the chain & it lasts me a year easily @5oo miles a week
I also suppose if you want the pose value DID Xring is the way to go
DID X ring is what I’ve always been told to use :slight_smile:
DID Xring and gold Renthal sprockets, naturally.
Got a DID X-Ring from here, does the job…
http://stores.ebay.co.uk/motorcycle-recycle1?_trksid=p2047675.l2563
struggling to find x ring did with 47 on the rear… pointers anyone?
Just email recycle with a request and they will change the rear sprocket for the size you need. Worked for me.
Cheers.
