ABSOLUTELY FUCKING DIABOLICAL SERVICE AND POWERBRONZE NEED A SERIOUS HEALTH AND SAFTY AUDIT!
Please elaborate. Are they the ones you bought the rear light off?
No…seriously beware of Power Bronze carbon front Mudguards as the Bronze Mesh is delicately stuck on with double sided grey tape that you can literally pull off with your little finger.
If the mesh gets dust / grit and wet becomes loose after riding then wedges itself between your brake disc and pad expect an endo stoppy!
Use epoxy resin to make sure this doesn’t happen…
The seller lied and said they usually use epoxy resin to attach the mesh but power bronze said they never have and are not worried about causing a possible crash…?
Powerbronze stuff isn’t cheap either… it’s not meant to be a bloody airfix kit you assemble yourself
I took the grey tape off and stuck the mesh in with epoxy resin like it should be…
It’s an accident waiting to happen!
Cheers I was just looking at a powrbronze rear hugger might give it a miss now.
King carbon would be the better option…
I must admit the hard work paid off and it looks spiffing!
TWAT
Keep it up, racist fucktard
