Winter brake service
Not included in a dealer service
Very simple job, just a few tools required, I did the Bonne’ in November using
6 x 100 mm flat blade screwdriver5 mm Allen key13 x 14 mm off set ring spannerbrush, bucket, soap and watergreen scouring pad2.5 x 50 mm flat blade screwdriverclutch & brake parts cleaner spray
An hour or two fettling the front and rear caliper and you’re brakes are good to go 'til spring
Del Boy shows how
You know you want to go on get stuck in :wink:
Del Boys other brake videos
Enjoy
Well done, Art! Its an easy job and will give you so much edge
