I’m removing the engine from my Hornet as I want to de-rust and repaint the frame as part of an overall refurb.
After sticking it on front and rear paddock stands and removing the header pipes can I use a trolley jack with a bit of wood between it and the sump to lower it out of the frame - then with some help lift it off the the jack and onto the floor?
The trolley jack/ thick piece of wood works well but needs a helper or two to steady the engine then hold that on the jack while you and another lift the bike frame over it/play silly bu88ers twiddling the jack leaning the engine a bit to push it out of the side.
Someone built like a brick $hit house will now come on and tell you that you can just lift it out. Yeah. Been their, had the hernia fixed.
