as far as i know it is mains feed - the hot water is from a tank. i cant see a toilet inlet valve i’ll check again. nope no valve to isolate the toilet
Chase the pipe that supplies the cistern back as far as you can, there should be an inline valve somewhere…
If you turned of the mains valve it’s gonna be hassle, you’ll have to drain all the water left in the system then you’ll have air in it when you switch back on…
A plumbers merchant will sell you a freeze kit, you spray the pipe and it creates a frozen blockage that lasts for a few minutes, enough for you to change the flush mech
thought you were joking there! apparently the previous owner says there is a cutoff hidden in the wall :ermm: so he is coming over to show me. good thing he moved two streets down the road!
If your hot water comes from a copper cylinder, you have a gravity fed system. There will be a large plastic tank in the loft, you need to go up and shut off the gate valve(s) from the tank. (red circular taps off BOTTOM of tank)
Yes you could drain the tank by running the bath tap until it stops but as ^ said you will get loads of air in system than can be a pain to remove.
Each time you disconnect pipework to a tap or water outlet fit one of these
The 15mm are about a £1.00 each and the 22mm are £1.50 each at Screwfix when you buy the 10 pack and it makes those little plumbing just that little plumbing jobs
