Water in indicator - warranty claim??
Hey guys, wanted to ask you for an advice- my rear left indicator is not waterproof enough - over time it accumulates moisture inside, the bulb gets covered in rust-like brown substance and it doesn’t blink as bright as the other ones do. I already opened it once to assess the situation and it looked terrible! I cleaned it as much as I could and dried it, but I’m afraid it is going to continue to accumulate water and might short one day…
With that in mind, my bike is still under Kawasaki warranty and I would like to know if it is a potential warranty claim? I hope that I wasn’t a numpty by opening it and cleaning it, so they could claim that my actions made it worse?
Thanks!
Not on upside down is it? Drain hole facing up?
I’d get that look at under warranty. have you done a search to see if anyone else is having the same problem on that bike?
sounds a likely candidate. either that or the rubber seal is missing
thanks for your replies guys!
The rubber seal is in place (checked), but I’m not sure about that drain hole that you are referring to, my indicators are completely sealed (no holes :D).
Tried searching for similar problems on Vulcan forums and it didn’t seem like something that happens too often.
will probably take it to the dealer to see what they say.
If you don’t get any joy with the warranty you could always drill a small hole on the underside.
The vulcan weighs a ton like a hardly ablson :smiley:
Obviously time to get a decent (light weight) bike :stuck_out_tongue:
Especially as one indicator has water in it :w00t:
Hardly Ableson, I’m using that one :wink:
Get a goldfish .
what’s up with this cruiser mockery here? :doze:
we tend to not like them. it’s nothing personal.
what did your dealer say about the moisture?
