Should you warm up a bike before you set of? (im thinking of Hondas here)
If you do need to then consider this:
I usually go to the gym in the mornings - a 2 min ride away - so if I warm the bike up before the gym it will be cold by the time i finish my workout, or should I warm it up again after the gym or only after the gym when im about to ride to work 40 min ride?
For a 2 minute ride, I wouldn’t even bother taking the bike. Instead, use the time to warm yourself up before hitting the weights or machines and run to the gym.
bearing in mind i know nothing, i have been told by some less than reliable sources that you should probably warm your bike up to get it out of the choke cycle before riding off, or only ride at low revs until the throttle responds to tweaks promptly.
This has something to do with coking up the plugs under choke, fuel consumption and valve seating and various other stuff that i dont understand.
Alternatively, i could have just typed a load of b0llocks.
usually warm mine up while I put lid & gloves on, and ride gentlyish for the first couple of mins… What’s really bad for engines is free revving them from cold - does wonders for cam-shafts etc… not…
I have always understood this too and always warm up older engines although I have been told that modern engines should NOT be warmed up as they are designed to ‘start and go’ and warming them up is actually worse for them. This is just what I have been told but have no idea what the reasons are behind this or even if it’s true.
