vapor clock, temperature and revs help
Hi,
I guess this was the best section to put this in thinking peeps may have installed these.
I have brought and fitted a vapor speedo for my 2001 hornet, for the temperature i got a stupid plastic t piece thats too small to go in the waterpipe so i’v wired it direct to the existing switch on the rad? seems to work? fingers crossed.
I now need to set up the max temperature and a warning temperature and dont know what to set it at.
Also if anyone could give me an idea what to set the revs at for each gear change, for the gear change light lol
I would be most grateful
cheers
Gary
i see you got an answer on the temp on the nest… regarding gear changing this might help… it for a 2005 hornet but should be similar - or give you a base line
Hi,
Thanks very much for this but for some reason i cant seem to open it in a readable format :hehe:
pm me your email and ill send it to you…
