I bought a USB charger with water proof cap and installed it on my bike, it only lasted a few weeks and spotted working.
All the electrical connections are sound.
Can anyone recommend a good quality one to charge i phone / go pro / sat nav .
Ps the crap one came of eBay
Typo stopped
what stopped working? has it got corrosion in the slots?
Jay - As per your paste below, I’ve deleted the images from here. I will upload them properly later. Sorry if I caused you any bother.
Aceman, stop pasting images, it doesn’t work properly (and I need to work out how to stop this being done). Please upload images instead.
Sorry Jay. I had no idea it was causing you a problem. I’ll delete them and then post them up with the “Add Photos” button.
Ok, that’s not worked. I’m unable to delete one picture.
I used the “pig tail” from the battery for the charger, bought an Optimate cigarette lighter adapter, and then bought a double USB adaptor for the cigarette lighter socket.
This means that I only have the small pig tail hanging down from the seat, and when I need it, I just plug my mobile and video camera up to it, and have them in the tank bag.
I bought an iPhone charger from twistyride, which is ace. I know it’s then locked to one item, but that’s all I use on the bike. It has a switch also.
Thanks for the info chaps, first, can i clean my usb with WD40?, i will try cleaning the point first. unless someone has a good usb charger that they can recommend.
Thanks for the info chaps, first, can i clean my usb with WD40?, i will try cleaning the point first. unless someone has a good usb charger that they can recommend. KTMJamesWouldn't contact cleaner be a better idea?
