djf01
11 November 2006 20:16
#1
Changed brake lines,
flled resevoir with fresh brake fluid.
Opened bleeed nipple and pumped brake… nothing.
level not going down, no fluid going out of bleed nipple.
I assume have air in the system. Kept pumping for a while, still nothing.
Please, anyone any ideas??
Edith
11 November 2006 21:05
#2
Keep pumping like there’s no tomorrow!
I tend to pump the brake lever three times and hold it in while I open and then close the bleed nipple. Do this about 300 times (maybe more!) and eventually the lever will start to stiffen up.
Do it some more and your brakes will be better than ever before.
There is also a way of sucking the fluid down through the new lines if this doesn’t work.
djf01
12 November 2006 20:11
#3
Thanks for the response. It certainly helped.
I was pumping for approx 20mins constant prior to any fluid and air bubbles coming through, either on the rear, or the front master cylinder.
Without the advice, re keep pumping, I would’ve given up, assuming something with the fitment of the lines was wrong!
Finally fitted, sorted! look the business.
Cheers!!
ps remember… keep pumping, it’ll happen!!
I bet your hand aches tomorrow
blade1
13 November 2006 12:50
#5
Hmmm, depends which “hand” he used? …(sorry, but u asked for it!!!)
lady_p
13 November 2006 17:36
#6
I was thinking that blade, but you put it better than I would…
smiled
13 November 2006 19:06
#7
FILTH…UTTER FILTH…
you’d never catch me making comments like that!!!
by the way…i use my right hand .
to pump you know…
i mean…to …
ohh what ever…
smiled .
djf01
13 November 2006 19:44
#8
yeah, now have to use other hand tobring bicep upto the same size as the other!!!
JasonB
13 November 2006 19:55
#9
You should of sat on your hand for 10 minutes, it would of felt like someone else doing your brakes.
