[quote]
swgixerlad (20/11/2014)
johnnybravo (20/11/2014)
a tyre thread, how novel
all that people will (and can do) in the main is recommend the tyre they use, which they often do not deviate from. If they crash on that tyre, its by default ‘awful’
The recommendation on this is far more to do with your ability, riding style and pace than ‘bit of road, bit of track’.
2cts are an excellent tyre…if you don’t ride in the winter. Yes you can manage on them fine but they are designed to work from about 10degC upwards (tried to find the exact number on michelin site but couldn’t ). So if you hammer about on B roads May to September and do regular trackdays it will perform well. If you’re new to trackdays/haven’t ridden one yet you’re prob not going to see much if any performance difference from the Pilot Roads (and possibly a fair bit less). If you’ve already done a few and are Inters upwards then go for the sportier tyre.
Worth bearing in mind is that its the UK (who knew) and cool or wet track temperatures are more than a little common. If you aren’t running wets then again, the Roads are probably the better overall choice. A LOT of people lob their bikes on the 3 warm up laps due to cold tyres so again if you do go with the 2CTs and its not going to be a warm dry day then tyre warmers would be a very good decision. Fundamentally its about having tyres that get up to temperature quickly, and then operate in their designed range. Plus the bike isn’t very powerful so won’t be asking as much of the rear tyre as say a litre sports bike
So basically your choice is either
Pilot Road (3, 4 etc) - very good mileage, gets warm quickly, holds its shape longer, operates best at moderate temperatures, strong wet performance
2ct (or other dual compound) - lower mileage, takes more time to warm up, summer tyre, soft outer additional grip when hot, steeper profile
Super corsa’s only if you’re going to rag it in August and don’t give a sh*t about mileage
Obviously would not disagree with any of the above but have to add I ride all year round on 2 cts odd knee down in wet cold conditions ( dick I know) and they have looked after me, but not claiming they are the ideal tyre either. Just that they work. Proof below… Loook at that traction!
<img src="data:image/jpeg;base64,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
I’m Scottish bud, that’s the sort summer weather we had as a nipper!
RE Maxxis ! Could not agree more, whats with that diamond tread bollox! No thank you! Might work in some foreign super hot tracks with top quality tarmac but not on good old Blighty roads! No thank you.
[quote]
[quote]
hammy
14 January 2015 19:31
24
PR3s it is … Fitted & awaiting a decent ride-out. Cheers for all the feedback. I’ll try to post some useful feedback on these myself once I’ve given them a proper go,
Hammy
