If I use a repair kit plug is that temporary fix (ie do I then have to go to a tyre fitters for a repair?) Therefore plan is ,get repair kit, ride to the tyre fitters…
I’d love to just whip the rear wheel off and take it myself but I’m miles away from a repairer and don’t have access to a car…
funnily enough, I’m working in SW18 tomorrow morning at 9am. I could help you plug it and you just give me the cash for the gas canisters. I did my tyre last week and ordered them so can show you the cost
How much air is it losing? A screw normally only leaks slowly in a tubeless tire so may not need plugging. I rode from Surrey/SW20 border to FWR with a screw in the tire a few weeks back with no problem but it was only losing a few PSI overnight.
An old timer’s roadside fix for a tubeless puncture is to screw a screw into it as a temporary fix. I know a few GOGs that carry some self tapping screws at all times for that very purpose.
Puncture repair strings. Meant to be temporary but most people I know use them as permanent. I pulled a nail out my rear tyre in May and plugged it with a string. Lasted fine until I replaced the tyre last month. I’m not Rossi on a litre bike though.
If you can plug it do it. If you use the gas cannisters make sure you get to a petrol station and let all the air out and refill it up to pressure.
Plugs can last the rest of the tyres life and you can have more than 1 in a tyre. I had three going to Wales, plugged them all and it lasted :blink: Had plugged tyres on track, not ideal but caused no problem, I suppose it all depends on how annual you are
I’ve decided I might as well learn to do this cos it can only happen again…
So I’m off to Infinity for a plug kit, wack it in (can’t e that hard surely?) and then tootle off to either FWR or OMC whichever can permanently fix it he quickest,
Thinking about it I can’t believe my luck - 30 odd years of riding and only a couple of punctures all of them on tubed tyres so no experience of tubeless flats.
Maybe there ain’t many chippies around here dropping there screws and nails all over the place…
