what tyre pressures are you using? do you find there is a lot of wear about an inch to two inches from the edges? tyre warmers might be some of the solution… certainly helps with cycle minimisation…also - how old are your CTs?
I’m running 30psi front and rear (cold). They’re about six months old and the wear is pretty consistent across the face of the tyre.
Hank
