I’ve bought this torque wrench a couple of years ago stupidly without much research. The range is between 28Nm and 210Nm. But quite a few bolts I tighten are in the 20-28Nm region.
On the wrench I can see there is some empty space between 28Nm and its default resting position (I guess 0Nm?). Now, say I set it to it’s supposed minimal value of 28Nm, and then turn it back 3Nm. How close would that be to 25Nm if at all? Am I the smartest person ever who cheated the system?
Your torque wrench is a lot more accurate then I expected a home I’ve to be (not actually got around to checking my own ones yet).
It’s within about 5% of the settings throughout the range.
If you want 25nm I’ve found that dropping it by 12nm from 28 seems to be fairly reliably 25nm, but to get it consistent hold it halfway down the handle. I’ll try and double check this later today.
