Hi,
I have a torque wrench which was dropped and came apart :w00t:
I’ve put it back together and was looking to get it recalibrated.
How much I would be looking to pay?
Has anybody ever got a wrech calibrated?
Hi,
Gawd knows how much it costs - I used to calibrate mine at work (in our calibration lab…
Don’t know how accurate this would be http://www.ehow.com/how_5622566_calibrate-torque-wrench.html
The answer to the “how accurate this will be” is not very.
Starts off with the basic misconception that distance from the load point (the nut/bolt) to where you grip the handle is critical. It’s not.
with internally sprung wrenches, it matters not where you grip the wrench, it’s all about internal spring load on the ratchet head and that’s constantly what you have dialled up.
You don’t believe me? Try a little practical experiment.
Without the right rig you can get things pretty spot on if you borrow another decent wrench. Tighten a bolt to a preset load with the good wrench, set your own to the same loading and try tightening the bolt again.
If it moves just a smidge, it’s ok.
If it clicks (releases) without any movement, load up your wrench in small stages until you get a tiny movement on the bolt. (or the reverse of course, but remember to reset the test bolt each time, if your wrench tightens the bolt.)
Now you have a measure of inaccuracy and you can adjust that out by trial and error.
Yes it’s a faff, but the good news is once you have it right at one point on the scale it’s probably right everywhere.
(Assuming it doesn’t have a progressively wound spring. If the graduations are equally spaced, it’s a plain spring and so Hook’s Law applies. Progressive spring/unequal markings? Buy a new wrench!)
Passing thought. We did manage to successfully work on mechanical stuff, including aluminium and magnesium aero engines with light weight fasteners, without torque wrenches, so 100% accuracy is rarely critical.
That stated, decent torque wrenches do make life easier and safer. Just don’t fret if it’s just a smidgeon out.
Now. Your wrench fell apart just because you dropped it? If mine did that I’d buy a better wrench.
Aye… if I dropped my big Teng one, the garage floor would break ![]()
