That Minarelli 660 lump again.
I know this has been here before. I dun post it. But this time it’s a bit different.
I’m trying to get together a working list of all the bikes that the Minarelli/Yamaha (same company for some year now) 650/660 4V single engine has been used in. (The reason for the list will become apparent on another post soon.)
I know it’s used in the Yamaha XT660 and MT 03 and the Aprilia Strada and Pegaso. But what else has it turned up in in, say, the last ten years or so?
If you know the answer to the above, is the easy way to tell the Minarelli motor from the similar Rotax to just look at which side the chain drive is on?
Derbi Mulhacen 659 is one
i thought the PIGasso had a Rotax lump:w00t:
I think the Pegaso had a Rotax engine up until 2005ish when they switched to Minarellis but I could be wrong
Now that’s the problem. As far as I’ve been able to find out Bomardier (reportedly) designed the Minarelli lump for Yamaha on a comission basis. O.K? Let that go for the moment.
But Bombardier also own Rotax.
Then there is BMW who used Cagiva (the then owners of Minarelli) to build engines for the early Funduros before switching engine production (I’m told) to Rotax.
Then there is MZ (or MuZ if you prefer) who (reportedly) started with Rotax engines for the Saxon series and early Baghira/Mastiff bikes and then switched to Minarelli built engines.
Confused? I am. Does anyone know the real history of this lump? Or is it lumps?
We are very sorry not to be able to help (but then you might in some way be slightly relieved about that, understandably so)
I was always lead to believe that the Rotax was the daddy of all the Minarelli lumps.
Same meat, different gravy;)
If only life were that simple.
As far as I can tell from photos, ther are a couple of subtle differences.
1: Side by side, they don’t even look the same.
2: The drive sprockets are on different sides.
Call me picky, but that kind of points to two different engines.
So you are saying an early Pigaso has a reversed drive train to a later one?
How odd is that?:w00t:
Not particularly.
Other manufacturers have done that shift, and if you think of it, it’s not that difficult. Pretty much just a new swinging arm and a different clutch cable and brake pipe.
I’ve seen it done on home brewed specials by amateurs in sheds.
