Taken the gsxr clutch out
The bike has a snappy clutch with next to no slip when pulling away from a standstill due to the clutch drying out over the 18 months it sat in the previous owners front room.
The new gasket turned up for the clutch cover and I got to work on it today and rebuild it 24 hours later. Not everyone has seen a clutch out or know how it’s done so I thought I’d put this up.
R/H side fairing off
Clutch cover off
Front plate off and first friction marked for location
All plates and steels out
Cable tied to keep in order and soaked in fresh oil
Shiv why did ya buy a shed of a bike? All you have done is taking apart.
Reg/rec replaced under warrenty and a dry clutch. Total cost to me £11 for the gasket. If someone could of spotted these problems before I’d be surprised.
intresting to see inside a bike for a change
you have to drain the oil first right?
Nope just leave the bike on the side stand with an oil catch under it. I had about a 1/4 of a mug come out when taking the cover off.
or lay it down on its left side :Whistling:
Cool. Thanks for sharing. I never seen this done.
Whenever I take things apart, there’s always “spare parts” left over :blink: That’s why I leave my bike alone.
Does your bike have a slipper clutch?
If it does, I believe those three black screws in the middle of the clutch with the nuts around them, are the lifter pins that control the amount of slip you get from the slipper clutch.
From memory, you turn them in to increase slip under deceleration and out to reduce slip.
Don’t turn them in too far though as you’ll get slip under normal acceleration.
If you still have problems after soaking the plates, then you can try this.
More info here (it’s for the K5 1000 but I think it should work on your 600 too):
http://www.gixxer.com/forums/showthread.php?t=202140
I’m just gonna leave it at factory and change one thing at a time. If this doesn’t solve it I’ll change the spring at the base
I had a snatchy clutch on the rattracker …It had sat for years in a box in bits . Did it all right soaked em for 24 hours in bike oil took the rust off the steels with wet nd dry … Put it back together … Still snatchy … Took it back out soaked them in gtx magnatec … Yeah the stuff ya dont use in bikes cos it makes the clutch slip … Put do back in filled bike with normal bike oil … Perfect job done slipped a bit to much at first but after a few miles though it all came good … Been good since … Touch wood :smiley:
Duno if a good idea with a modern bike though … I distance myself from any **** up made by doin any things I do :wink:
Why do you want your clutch to slip when pulling away? Or do you mean the biting point is to sharp. :slight_smile:
Slip is what clutches need to do as you feed them in. Bite point is where it stops slipping.
If you don’t have controllable clutch slip, it makes riding/driving a real dog. There is at least some slippage built into race bikes and cars, even F1 cars*.
(*They tend to spend £numerous with two or three clutches and a shed load of electronics to control the complexity of feeding them in and call the whole set up “launch control” or some such.)
Well it works perfect :slight_smile: I adjusted the push rod while I was there and set the clutch cable again and it’s lovely.
Congrats.
Good to hear :slight_smile:
After 50 years of effing about with (including some effing up!) of things mechanical, I still think it’s a great feeling when you do a job and everything works as it should again.
You got that right and all things I’m going are going my way touch wood
