I’m looking at replacing the front end on my project Bros 400, and wondering what will fit.
I know most Honda ones are straight swap if it take the triples too (and some dont even need that)
But if i look at other makes I can check if the steering stem diameter is correct using this table from AllBalls.
Its a bit harder to check if the height of the stem is compatible, but still relativity easy. If its not most people talk about pressing out the old one and put the Bros’ one in its place. I have access to a press at work, is it and simple as press one out, press one in? How do I check the diameter of the section that’s pressed into the triple?
If the height of the stem is correct, then yeah. But if I’m changing the stem then It needs to have an interference fit with the yoke, and I’m not sure what else matters
