Toony’s 2000 SV650 died yesterday and won’t restart, it turns over but just won’t fire up. when you switch the ignition on you can’t here a Fuel pump priming, (does a Curvy SV have a fuel pump or is it syphoned into the carb via a vacuum??) it would seem there is either no fuel getting in or there is no spark, i checked what i could with the tool kit in the boot and without getting it to my house with my tools can’t really go too far into it. A quick Google says it seems like a common problem but there are 2 or 3 different explanations,
Duff Battery
Regulator/Rectifier
Electrical Fault
It’s just been serviced so the Plugs/Filters etc are fine, the Oil is at the correct level with no leaks. But prior to last week it had been sat in my garage for 2 or 3 Months not moving. It started on the button every time i tried it, and also started first time when he come to pick it up, it just seems since the really cold weather has kicked in it has developed this fault (which would suggest it could be just the Battery)
I don’t know if curvy has this problem, but mine(pointy) had wire broken under the air filter in between the front of filter box and frame. It’s apparently the only thing which goes wrong on pointy sv650. On mine when ignition was switched on, all the dashboard lights were on, but there was not a single sound of life when I was turning the key(no fuel pump, starter, anything).
I know you’ll have checked the kill switch, but just for reference, some bikes (like mine) will turn over even with the kill switch enabled, they just won’t fire up. If you are used a bike where the kill switch completely kills the ignition circuit then you mightn’t realise this is why it won’t start and only realise once you’ve pushed it to a petrol station.
Marmablade
i think i would start with the battery mate. by just starting up the bike you probably killed the battery for good. the battery needs the bike to run in order to recharge so if you just start it up without moving it would just kill it eventually.
