No - but the zx7r forum says they will bolt straight on.
I’m assuming the four pot nissins remained the same throughout the bandit model run e.g. from 95 to present - so I won’t need to get a caliper from a specific bandit 1200.
I’m really pi1ssed off now - just want to part ex the 7r.
I’ll phone up a suzuki dealer/parts specialist if replacement nissin four pots will fit any bandit model from the early oil cooled ones to the latest water cooled ones and if they also fit the 7r then there shouldn’t be a problem in getting a set off ebay.
The 2nd gen Bandit 1200 introduced in 2001 changed to the six pot Tokicos.
Having had them on a ZX-9R I reckon you’re correct in looking to replace them with some 4 pot ones.
Didn’t you recently rebuild them ? I think I remember you talking about how expensive a full set of seals cost? If so, I’m surprised they’ve seized up so soon.
The tokicos seem to be notorious for seizing up at the drop of a hat - my rebuild doesn’t seem to have done me any favours - most people are happy to see the back of them and put four pots on.
Thanks for the info - hopefully i’ll see some affordable ones come up on fleabay.
Part of me wants to take the calipers to a shop to see if they can pop them out but I’m convinced they are absolutely jammed and it will be a waste of time and money even trying . . .
Take em into ER on your way into work tomorrow? If they are buggered Mick prob wont charge you anything for having a look. Open from 830 get there a bit before.
Replace with Bandit 1200 (1996-1999, mk1) Nissin 4-pot calipers.
Rejoice, for your task is complete
They get rid of the spongy feeling, excessive lever travel and excessive brake fade- I’ve no idea why the stock calipers are so crap, but they are. After researching this extensively, it seems that Nissin spent a lot more time corrosion-proofing their calipers, whereas Tokico just played with their balls to pass the time.
Completely 100% bolt straight on, if you’re using braided lines you might have to change banjos for ones with a finer thread (Nissin runs a slightly finer one than Tokico)
They’re centred to the disc, 90mm spacing between mounts, and they work.
I’ve spent about 5 years, 3 sets of discs, 10 sets of pads, new caliper seals, 2 different sets of lines and countless fluid changes, just to find I should have got rid of the 6-pots.
The 6 pots on mine have been great since I gave them a full rebuild with rubber grease on the pistons. I do know they can gung up quite easily though, I’ll swap to the 4 pots when they start to play up I reckon…
@ninja junkie you can fit the bandit calipers, but a better 4 pot caliper to go for are the 4pot tokico’s fitted to the gsxr600 SRAD’s and the TL1000S much better caliper and about the same price second hand.
bear in mind that these calipers will also be at the youngest, 12 years old and will need probable cleaning/new seals. however once they are done they will be much better than the 6pots and require less maintenance
Thanks fellas - yeah - hopefully the bandit calipers will be much better.
General consesus seems to be that 6 pot toks are a pain in the arse . . .
Now I’m worrried that the piston sticking incident might have cause the pads to score the discs and result in an MOT failure - I’m going to take the front wheel to the mot tester to find out if he’ll pass the discs or not . . .
Mate - these are proper stuck - they are wedged right in so there is not much space behind them to build up serious pressure - I’ve also read threads where people with proper stuck tokicos have binned them because not even compressed air at 100 psi will move them.
Is this a front calliper on a 9 fella, cos if it is… use some mole grips, screw the damage and you can have one of the pistons Ive got kickin round hte garage… seriously…
