I have been bought a pair of Dainese Nighthawk short boots by my wife, she used the size I have for a different pair of Dainese boots.
They are a bit tight, particularly the left one- and after an hour my left foot in numb.
Can I safely use a boot stretcher on these?
Any tips for getting a bit more width from the boots?
Unfortunately they were bought out of the country so I can’t simply return them.
I had the same problem with my pair but they give up in the end. Worst case scenario, submerge them on hot water while you wear them (you will get to test how waterproof they are too)
Thanks folks- I’ll start with the stretchers and then try other methods if they don’t work.
It is only a mm or two that I need I reckon and only on the left boot.
