I currently have an issue where I have a door with a bolt lock downwards (in the door, pointing down), but the position where I’d extrude the bolt has no hole in the step.
I assume a drilling machine should do the trick, but I would neither know if it needs a special drill (it’s a fairly large stone step), nor do I own a driller with all specialties etc.
Has anyone got any experience with this? If so, I may need yer service at a point quite soonish
is it viable to take the sliding latch off and put it back on the door horizontally? then you could fix a lug on the door frame and you would not need to drill the step and could do this using only a screwdriver. not as secure but if they wanna break in they will anyway. use big screws and plenty of them.
vertically is unfortunately not viable, since I can only attach this inside, but would need to be able to (un-)lock and open the door from outside.
it’s also an internal bolt thingy, inside the frame, so would need a new bolt-lock anyway (minor detail though).
damage to the step, as in drilling a hole, is no problem at all (as in, no one will complain, and no one would really care)
You just need to drill a hole under the bolt so that it has somewhere to drop into?
Close the door, mark the position where the bolt falls and drill a hole big enough for the bolt to fall into - 10 minute job and unless it a huge bolt any old cheap hammer drill should do it - you’d probably pick one up for under £20 from argos and it would fit in a backpack.
I could lend you one but I’m in central/south london
it probably would, although along with the charger and bit set, it would weigh quite a bit, probably better strapped to the seat, your welcome to borrow it, or let me know an exact location (what tube station its near) and I might be able to swing by and drill it for ya
If it’s a real stone step,FOR SH**S sake don’t hammer drill it.
Almost all natural stone will drill with a decent, sharp masonry drill bit in simple rotary mode. Hammer drill it and you stand a good chance of it cracking and splitting. (Something builders seem quite unable to understand.)
If it’s concrete, do what you like.
Good general rule: Drill a small hole to start with and work up the size bit by bit.
