Sticky gearbox on a Hornet
Hey guys, hope you’re all enjoying the sunshine out there! Time for a Kawasicky me thinks :wink:
Anyway, my gearbox is now sticking. Just started after the weekend there. Bike wasn’t damaged and hasn’t had any work done recently, it’s just started to stick. Any ideas what might be causing it?
You probably just need to remove the foot controls and lube it all up - I expect the pivot on the gear lever has got all cruddy.
Change the oil, And stick an elastic band round the clutch lever and leave it running may be sticking if the oil is old
as above strip and clean then grease all pivot points !:wink:
