I bought some steel brake lines second hand recently, they were a bit dirty and had no plastic sleeves.
Easy solution - shrink wrap.
I found that 12.7mm was the right size for mine, I had to remove one end of the steel ‘ring’ fitting first (perhaps someone can chime in with the real name).
And that looks like it worked out great for you! Is it heavy duty shrink wrap though? the stuff I used on electrical connections doesn’t look like it would hold up very well…
Aaahh… it is a banjo! I had an idea it might be but wasn’t too sure. Thanks.
No, it seems quite tough although it isn’t labelled as heavy duty to be honest and I haven’t put them on or used them (perhaps it’s a bit premature to judge).
But seeing as they are really only for water and dust proofing the braided steel, they should be okay.
lol, no there is the banjo onto which the olive slips onto and then the nut which is over the braided hose bolts too and squashes the olive to make a seal.
Why didnt you clean the banjo’s fully? Get the gunk clear and all polished up.
Yes, new olives would have been best (I hope you have new copper washers?)
Personally I would clean as they are now and fit them. If they leak…then you can take them off and do it again.
The sleeving i think is awesome. Great idea. Love the fact how simple it is, even fact that you can get heatshrink in most colours meaning the lines can be customised into different colours! You could almost do stripes of two different colours all the way on the.
Yea, I took the photos before cleaning out the rust from the banjoes, but it’s gone now.
I could have a go at them with the polishing bit of a Dremel, but to be honest, they won’t need to be shiny shiny, it’s not my thing.
My mechanic friend has loads of copper washers lying around, I’ll ask him about the olives though.
Thanks, however I have yet to test them under ‘working conditions’, so I’m not sure how they’ll do.
Also, I can’t actually see many people being in this position (having brake lines without plastic sleeving).
But it’s nice to know I suppose.
