Never done this job on an engine like this before, and to save me wasting a ton of money on shims…
When shimming engine valves so they have the correct clearance to the cam, is it possible to stack ones of different thickness to get the correct clearance, or do you replace the existing shim with a thicker one?
To be specific, this is on a 96 Honda CB500V parallel twin engine with DOHC and shims under bucket.
The clearances are super tight and I think they were never checked before by the previous owners of this high mileage bike.
hmm in answer you need to replace with thicker /thinner …as stacking could mean a shim moves when no pressure exerted and heads into the gubbins below !!!
Old experience on shim and bucket engines (but never on a Honda, though it should hold true) si to take things in sensible stages. So:
Note your existing clearances valve by valve.
Work out what “new” shims should be to get the right clearance. (As in +/- whatever)
Strip down to get the shims out and measure them.
See if you can swap a few/couple/one to give you what you need.
Only then go buy the new shims for the rest of the valves. (If you can find a dealer that has what you need in stock!)
These things seem to be silly expensive for what they are so any re-use is worth the very small extra effort.
If all else fails, you can thin them down either on fine emery paper or an oil stone but that is a last resort as they are case hardened and you will be through to the soft core after a few thou.
