If it’s been standing for a week or more out in the open or in a damp or badly ventilated garage, try a few “emergency stops” using the front brake, see if that helps.
Hmm. Don’t overdo the stops if you are fairly new to the bike. You don’t want to lose the front end quite yet. Oh, and do make sure there is no one too close behind you.
drip some oil between the front forks and the hub of the front wheel should clear it up of any noise as i had that noise in my front wheel of my old aerox100 once i did that the noise went.
sorry im confused was the noise coming when breaking or just rinding normally with no pressue oput on the brakes? if its when your braking then will be brake pads , brake dust or road dirt can cause that.
