Splicing electrical connectors
Yo folks,
Since moving up from five to six gears can be confusing to a wee brain like mine, I’ve decided to fit an Acumen digital gear indicator:
However, there is no plug and play connector for my bike and I will have to splice into the wiring loom to get it to work.
Several questions here for the handymen among us:
  • Rather than using clamp blocks, I think soldering the connections and taping them up with electrical tape is the way to go. Is there any special solder I should use, or the same stuff I used for my pet science projects in school also good for bike applications?
  • Do I need any special tools to get behind the clocks of my bike? Do I have to take the whole @#!@# nose cone off? (Hey I knew getting a faired bike was gonna be trouble :w00t: )
  • Also I’m fitting one of these puppies hooked up to a Pt100 temperature sensor so I can see how tough I am for riding in this cold :cool:
I’ll be installing the temperature readout recessed in the right fairing, but does any 'Bird owner have a good idea for a place to fit the sensor where it isn’t affected by waste heat from the engine, yet still gets enough fresh air to deliver an accurate reading?
Ta, Stefan Mechanic
this prob wont much much use but an idea
instead of taping it up why dont you use heat shrink it will look neater
Yeah shrink tube is a brilliant idea, I think I’ll go with that.
Not sure you have much choice on the solder front (all lead free now)
But silver solder is good…:wink:
I did not actually ‘split’ the wires when fitting mine.
Removed the front plastics to get good access to the rear of the clocks/loom.
Carefully bared the required sheath on one side to expose the cable core and then soldered the (very thin) acumen wires onto that, then applied a load of insulating tape over the top.
:smiley:
For soldering onto the loom I would recommend you get a set of automatic wire strippers like these;
http://lkl-products.co.uk/index.php?main_page=product_info&products_id=42
they break & pull back the insulation only without damaging the wire. Saves you loads of time when doing electrics, you will have to use insulating tape though not heatshrink.
