Spark plugs issue for my Fazer
Hi, i am looking to upgrade for some iridium ones for my Fazer 98.
However seeing this ones as for example Iridium Sparks these have a gap of 0.6mm, however on the manual it says: Spark plug gap
0.7 - 0.8 mm, are the ebay ones suitable?
Hope you can help
Cheers
Yes, you should be gapping plugs anyway before putting them in
The maual says that the partfinder is: CR8EIX however on ebay, say that for a fzs600 98 partfinder: CR9EIX also fits…
It is a tricky situation though, Price variates a lot.
Hope you can help
Yeah fine, they’re slightly different temperature ratings but (IMO) both will be fine.
Alex that has been very helful, thanks very much! these arent worse than the CR8 ones no?
They’re rated to a lower temp so should work better in this country! I’m fairly sure they’re not so far out of spec as to cause problems, but I’m waiting for someone to tell me they will! My scooter there was an option to go with a different plug if you were doing lots of short runs as the engine temp would be different.
