hi all and terry
right were do i start as posted by exile yep its currently a push bike
decided to rewire the bike from scratch
all the lights indicators instument nos ect work
one of the carbs was overflowing sorted that cleaned the whole bank
put new petrol in petrol definatly getting to carbs
however it wont start
cleaned the spark plugs and checked that i was getting a spark out of all 4 spark plugs that seems fine
double checked id wired in the ignitor correctly that all seems fine been told if it wasent i wouldent get a spark at the plug ?
re-looked at the wiring diagrame got neutral light showing when i put it into gear the neutral light goes out
only reason im telling you this is that i dont use a side stand switch i dont think that is the problem
when cranking it over all you hear is the starter moter trying to turn over the engine but no hint of it firing some spluttering of the carbs thats it
i cheked the ignition pick up just incase something came loose when i was putting the engine back in the frame all seems well
ive tried quick start no help
so what next???
anyone in the area who can help me out would be appreciated otherwise it looks like im writting off this years riding
cheers guys
