Slipping hot grips
When my Oxford Grips get hot the glue goes soft and you can slide them about. It’s a bit weird, anybody else have this and anybody got any ideas of a better glue rather than the stuff supplied with them?
Thanks
Did you used the glue supplied???
I used proper Superglue (not the stuff supplied, but Loctite’s own) with no probs so far, about 3 weeks later.
I have an email from Oxford that confirms that the special glue is any old gel superglue. If they get loose when hot, just slide them off, or at least most of the way off, and put some more glue on them and slide them back. Worked for me (both times!)
Used superglue on mine and they are rock solid.
