I currently own a CBR125R '55 and am getting it part exchanged on the weekend. Unfortunately since last weekend, the bike has developed a kind of screeching when it is first turned on. But, if the bike has been running for anything over 5 minutes or been thrashed around for a little bit, the bike will not have this screeching as long as it stays reasonably warm. E.g. killing the ignition and reigniting the bike will not demonstrate the same screeching.
Now, the only recent things that have changed was a recent service and the temperatures plummeting. Now, my mind is telling me that it is most likely the cold as the bike will stop doing it once it has run warm with the choke for a while. But the other side of me thinks something has been adjusted in the service and is causing the issue. (Although the issue only developed a week later)
What do you guys think? Service or weather? Concern for selling the bike or something that could be overlooked? (E.g. I keep the bike warm before the dealer turns up and hope for the best)
Sounds like an oil problem, check the level and the viscosity
If I was a gambling man I’d wager it had a straight SAE30 or SAE40 oil put in at the service. Ask the garage what oil they put in, query it and tell them the problem you’re experiencing. With the recent cold snap the oil viscosity is important especially if its a street kept bike. It needs a 10W/40 motorcycle oil.
I use and recommend Castrol Power 1 4T 10W/40 part synthetic motorcycle engine oil in Art juniors CG125, works a treat and only £9.99 off the shelf in Halfords
