You have to have a ‘prescribed’ ID - that means a passport, other driving licence (new style) or a photograph certified to be you by a relevant professional. If you don’t have any of these you need to get one or you can’t sit the test.
Currently to pass a UK driving test you have to
Pass a theory exam - 35 questions, you have to answer 30 correctly - the theory test also now includes a ‘hazard perception’ test where you have to watch various videos and correctly identify emerging hazards as the develop.
You then have to sit you practical exam, there’s no requirement to take a certain amount of lessons, the exam is between 30 mins and 1 hour depending on your ability (the examiner takes as long as is needed) during the test you are taken on all types of UK roads, excluding Motorways, and you must perform a series of ‘manovers’ these include a 3 point turn - or more correctly described as a turn in the road - parallel parking - corner reverse - emergency stop - hill start - and several others - you must show you are competent in all of these areas before you can pass.
By passing your car test, you are not entitled to drive any other vehicle, excluding vans under 7.5 tons or minibusses. In order to drive other classes of vehicle you have to pass separate tests, both theory and practical.
As for bikes… I’m sure you know this but… again it’s theory, hazard perception, then CBT, then test with lots of rules about power… etc etc…
There’s no sep test for winter / summer as I would imagine the DSA (Driving Standards Agency) believe there’s not that much of an actual difference in the Uk - whereas in Finland I’m guessing there’s more seasonal variation.
Incidentally, after applying for and gaining your ‘provisional licence’ which allows you to take lessons, you have a limited time in which to pass your test - if you fail your test you have to wait 6 weeks before you can take it again.
I think I’ve covered most parts - but I’f I’ve been inacurate anywhere I’m sure someone will correct me.
So I guess in comparison, it’s about the same, or Finland is slightly more difficult to pass.
m
