rg125 gamma
hi all just a quick one. i am trying to find the oil pump on my gamma and the engine number i cant find it i have been looking all day… and i also found a round metal thing in the box off bits it looks like a propeller? with a hole in the middle. (sorry my cam’s broke or id take pictures.) and were is the oil tank located??? and wot oil do i use in the gear box sorry i am new to bikes.:hehe:
Sounds like you need a visit to a bookshop for a Haynes manual:D
engine number is under the left side off the engine it might be covered in crap and you have to remove the belly pan if you got one.
the round thing is most probably a spare water pump propeller… it runs off ur crank the more you rev the faster the engine goes and the propeller etc etc…
the oil tank is under the fuel cap in front off were u fill the tank with fuel have you not seen it when filling up!
and the oil pump is located under the left side engine cover take the main cover off the behind the front sprocket u will see another cover with 2 screws holding it on it located behind there…
and in the gear box just use silkoline light gear oil.
and get a cd manual off ebay 9.99 haynes dont make one for the gamma so you will need a suzuki one.
lad knows his shiznit:cool::wink:
ok cheers .oh and theres a round metal bit with like a plunger on it and a big spring in the middle off it and a rubber seal over the top wot is that?? there loads off stuff in this box i donno wot it is!..
thermostat- just put a list up ill tell you wot it all is and get it out the way!..
1-black box with 4 wire connector block on it and another wire with to pin block.
2-round thing with magnets in it
3-a tent like shaped plastic block with metal tabs on it.
4-i big round thing with coil windings on it and a little black plastic bit with a round circular metal bit on top(that’s tiny)
5- and a long copper thing that had a threaded bottom and a green wire coming off the top
i no wot the rest is cheers.
1=power valve control box
2=fly wheel
3= reed block and reeds
4=altornator & pick up coil
5=temp switch
:hehe::P;);):wink:
yes the rest off it is the motorbike:w00t:
