ok so I reason my reg/rec is knackered. it’s on 33k, when the bike gets hot from slow speeds in the sun, the battery dies ie not charging. battery has been replaced.
IF it doesn’t, would a haynes allow me to see the wiring pattern? I take it’s there’s 3 wires from the alternator (AC) then 2 (+/-) out back into the system. is that right? I’ve no problem ritting spade connectors to the wires to fit it.
Rather than fitting one from the Yam (not that I know anything about this mod), wouldn’t you be better using a sheet of aluminum or a heat sink paste to help it run cooler? Perhaps even wire in a PC fan?
You need a mosfet reg. The shunt regs all get irrationally hot. Heat sinks help, some people fit computer fans. Mosfet units run cool and are a great deal more resilient than the shunt type.
Lots second hand on Fleabay. They look like this:
This thread is vfr specific:
Clean the back of the new rect/reg & the area where the rect/reg sits against your frame. Then use computer CPU thermal paste (silver type) on the back of the rect/ reg. It will dissipate heat much better.
I did this on my blade, and it runs much cooler now.
Ok run the bike up to normal running temp check the voltage then hold the revs at 5k and see what the voltage reads at. Anything over 15 and it’s breaking down at temp
it’s close to 15v at 7k. I took it for a ride today and it was very hot very quick. 10 mins or so and I could feel the heat on my knee through the air gap and fairing. think it might be a duff purchase
my mate directed me to the haynes manual section where it lists all the resistance settings. I’ll be checking those tonight, as well as those on the old unit.
bought another unit from ebay that the previous owner had tested as working (he had 3 spares). invited a mate over who knows more about electrics than I do and he was getting some weird readings on all 3 units off the bike.
I’ve sent the 2 rectifiers off to honda to be checked now. I’m doing something wrong somewhere.
