Renthal's For An 06 Hornet 600
Hey all
had a good ride yesterday to the Ace after work, it was a bit windy but coming over some of the flyers at speed i was getting a lot of shaking from the front.
i’m putting it down to the bars, they are standard and quite narrow, a mate who was with us was also on a hornet and had no worries with shaking but he has Renthal Ultra Low bars which are that bit lower and wider than standard, so i’m thinking do i change them!?
what i am after is something a bit wider than standard but not stupidly wide! i filter so they need to be a sensible width and i dont want the brace thingy across it.
what bars tho, any hornet owners got any views??
Personally I’d rule out an out of profile front tyre and head bearing wear/adjustment first.
I’ve ridden that vintage of Hornet enthusiastically and never had a problem with head shaking. But then I am a phat phucker so probably keep the front pinned to the tarmac :stuck_out_tongue: :slight_smile:
also never really had any issues with shacking. as mentioned on FB i had UL and they are perfect, nice low to bring you fwd and wide but not too wide
front tyre is pretty much brand new, it only does if its windy or on wide open m-ways etc, i’m not a massive wheelie merchant and bike has fairly low milage for its age, i think its the bars due to how narrow they are but will get head race checked.
also i am slim and only about 10 stone most bikes get lively when i really push them:D
maybe i should go and buy something better? but i like my little hornet
I have lower wider bars on my Hornet, I’ll check what it is I think it might be Renthal, never had any issues but also cannot compare as I bought it with these and never had standard bars
kool beans George, swing by the shop if your out and about on it?
btw got them boots if you still need em:)
id rule out any malfunction on the horny before changing the bars. the renthal bars are thicker and therefore heavier than standard. only helps for mirror vibes. My 2pence is unbalanced wheel or headstock or similar.
been thinking about the bars for a while, lose the chrome ones:sick:
i’m pretty sure the head race etc is fine, it doesnt feel notchy but will have it properly looked at.
When you gonna start the mods bob?
Renthal ultra lows are 22mm diameter so should be a straight swap your stock handlebars.
Not sure how much wider than stock they are though.
You Should be able to work it out from the dimensions table here.
http://www.bandcexpress.co.uk/handlebars/handlebar-dimensions.html
Hes got to get the balls to get the tools out first…
:rolleyes:
