Wore my nearly new, ultra clean waterproof last Saturday and got chain lube on one arm and one cuff while trying to help out a fellow rider.
Took off the worst with a wet wipe and then did the “soft soap and water with a brush” bit of the cleaning instructions when I got home. So now I just have grease stains.
In a years time, I won’t give a sh*t, but I emailed Frank Thomas for advice and guess what they recommended. That don’t work, I told them. What else can I do? Got the predictable pompous reply.
So, real point. What do you use without disolving the 100% nylon shell/100% polyester padding/100% nylon lining?
Swarfega, Muckoff, white spirit, meths?
(Note to self: Must remember to buy black riding gear again next time.)
If they’re cotton denim you can hit them with almost anything. though don’t try my great idea: Soften the grease with meths and then draw it out into kitchen roll using a hot iron.
Essential part of any toolkit - WD40. That’ll shift it.Remember Fred Wedlock and his Best Universal Grit, Grime & Effluent Remover? “If OMO won’t whiten it and Daz won’t brighten it, B.U.G.G.E.R. it!!”
Best bet for removing anything oil or grease related is paraffin. If you can’t find paraffin, go to Homebase or B&Q, buy a big bottle of barbeque fuel, think its the same. About 5 quid for 4 litres, will last a long time.
Paraffin - blimey just given me a flashback on up the road where I used to live when I was a kid, my nan’s heater was paraffin fuelled and we used to go up the road to get the bottle refilled from a token operated paraffin vending machine !
