I have an Abba rear stand which is brilliant but I would like to get a front stand to (ideally) use at the same time as the Abba rear to make cleaning the front easier, lazy I know
I have R&G front fork protectors so am not sure what to look or what I need for a front stand ?
the best front stand at the moment in the new motrax one. Its design is great in that it means you have loads of room to work on the front (changing wheels etc) wheras the normall prong type fronts get in the way when changing wheels.
If you need to get your forks out iโd reccoment using an under yoke stand. Most cheap ones from ebay are good enough for this as long as they have various adapters for the different size stems.
